I am new to using lasers, I have a Two Trees TS2 laser and I was trying to do an engrave test but all I get is lines or this mess which is supposed to be text.
I have done a few engrave tests recently and I had no issues apart from needing to adjust the belts and eccentric nuts.
I would be grateful for any help.
Did you check the bels again?
Without more information I would say this is mechanical issue. So check belts and eccentric nuts again. If not properly tighten they will be loose again soon.
To me it looks like an unauthorized version of LightBurn, write to support@lightburnsoftware.co them for clarification.
Thanks, I was given the software to install and now that I have removed it and installed it from the website itself it now works.
