Cannot open materials parameters in LightBurn
Hi,
Just bought a fiber laser and want to download a materials parameters library from The Laser Master Academy, which have been essentially useless in helping me. So I thought I would try here because of past successes.
I am on a Mac with Sonoma 14.5, I am also using LightBurn 1.6.03. I initially downloaded the document and got the message that I do not have an application to open this. I finally set it to open it in Text Editor ( do not know if that is the correct application ). I then tried dragging it into LightBurn’s library and now it tells me that LightBurn does not recognize the file extension. File name is: MarkParam.clb. I think this is an easy fix, but I do not know where to go from here.
Your help will be much appreciated.
Jim
From the Library tab, click Load, navigate to the .clb file and select it, click Open and it will be loaded into the library.
Hi Tim,
I think I got it with your help. The library is populated and there are parameters there. I thank you very, very much.
Jim
