Cannot reach "OK" button of Cut Settings Editor to change/save settings in Lightburn 2.0x
Since upgrading to 2.0x the “Cut Settings Editor” window opens taller than my screen, and does not shrink enough dragging the edges to be able to see and click the OK button to close it saving changes.
The workaround I have found for now is unlocking the taskbar and moving it to the side, but obviously this isn’t ideal. I haven’t figured out yet if this also applies to other pop-up windows (“Preview”, “General Settings” and “Device Settings” are all fine).
I tried installing the RC of 2.0.02, but it’s the same as in the main release 2.0.01.
I have a screen recording which hopefully shows the problem: Link
Thanks.
I’m using Windows 10, at 100% display scale, and tried restarting with the “Enable High DPI Scaling” (and the other DPI related) option.
I did find another workaround, which is reducing the font size in the display section in the system options of Lightburn, which leaves the window just with a tiny part of the OK button visible without having to move the taskbar. EDIT: THIS WORKAROUND ONLY WORKS IN 2.0.02 RC, NOT IN 2.0.01, MAYBE THIS INFO HELPS?!?)
Thank you for reporting. Investigation further. :slight_smile:
@MungoJerry, Edit → Settings → Display (tab). Reduce the font size one or two notches. That affects the entire UI including the max height of those windows.
