Cannot select line in node editing. Version 2.0.02
When in node editing, cannot select some lines, not all. I have to us the select tool, highlight it then go into the node editing. There are no duplicate lines nor are they grouped. Also lose the bottom pallet color when zooming in and out. Tried the reset to default layout to fix. Only started to happen when upgraded to version 2.0.02. Using a Windows 11 all-in-one Lenovo computer.
Not sure what you mean by “select”. Can you upload the .lbrn2 file so we can examine it?
Node edit works when I convert circle to path.
Hello, I had to convert ellipse to path to node edit it.
That is because an ellipse, as well as the other “regular polygon shapes”, do not have a start or finish until converted.
You are back in business now?
Yes, thank you.
