I had an very cheap camera configured, but changed it out for a Logitech c920…
Problem is i cant run lens calibration… I have picture, but after selecting No fisheye, on the next page when i click capture, nothing happens…
Pluging back in the old quickcam 9000 it works as it should…
Any idea?..
PS: camera alignement works, but the picture gets distorted since the lens correction is wrong
Not that I know of. That’s one of the drawbacks of using Default.
Make sure that you’re using the fastest USB connection that you have. I’m wondering if you’re bandwidth limited which is why you’re not getting faster options and why Custom might not be working.
Are you on a hub or extension cable? If so, plug in directly and see if that changes anything.
