I have a 60 watt Chinese with a rudiha controller and lightburn will not find it during initial setup of software. please advise
What kind of Ruida controller are you using? How are you connecting it to your computer? What operating system is your computer using? What have you tried, and what were the outcomes?
I have tried connecting with a USB cable directly to the âPCâ port on the laser. when I open lightburn and it ask if I want it to scan for device it doesnât find my laser. I have the laser on and control board is on. tried with cooling and air on and off still nothing. I have a fairly new 64 bit thinkpad which is the software version I downloaded. here is the only info I know about the laser.
Brand: | ## Preenex |
PC Interface: | USB 2.0 and USB Disk |
Software: | RDWorks V8, PowerCut, CorelDraw or AutoCAD |
Image Form: | HPGL, BMP, GIF, JPG, JPEG, DXF, DST, AI |
Machine Dimension (L / W / H): | 47.2" x 34.2" x 36.6"(1200 x 870 x 930 mm) |
Package: | Standard Wooden case for export |
N.W.: | 330.7 lbs (150 kg) |
Maximum engraving depth: | 3-4mm for acrylic, wood, 2-3mm for harder material |
Maximum cutting depth: | 5mm for acrylic, wood, 4mm for harder materials |
Maximum engraving area: | 700 * 500 mm |
Warranty: | 2 years warranty |
UPC: | ## 729270389690 |
When you plug in the laser to your USB, does it make the âdingâ sound, acknowledging youâve connected a device?
yes it does. I also went in and chose rudiha controller manually and set up but laser does not move to software demands. the âset laser position buttonâ does not move the axis
Did you install the FTDI drivers, at the end of the Lightburn install?
not sure. I downloaded the program the last week to start practicing. How can I check?
Reinstall the program, and make sure the checkbox is checked for it.
Uninstalled and reinstalled. Interesting that where I had manually loaded the controller it showed up after the download. I got it to move once with the move key but then it quit.
I appreciate your help here. Please donât give up on me. I am heading out and will try again later this afternoon
Thanks
NP. Let us know how it goes.
The software quit, or it moved, and then stopped moving? Did you press the button again? Did it move again? We donât charge by the word here, and being as descriptive as possible will help us help you.
