Hi guys, rookie question. trying to engrave a single letter. Lign everything up, Do a trace and all looks good. red light pointing to centre of letter. Press start and the actual engraving takes place an inch below where the trace was. What am I missing??? Starting from user origin and job origin is centre dot.
I’m not using the snapmaker on this job. It’s in the light burn settings as it worked fine a few days ago. I think I have changed a setting or something
Where did you have the laser positioned when you clicked the ‘Set Origin’ button? (If you didn’t click that button, you probably meant to use ‘Current Position’ mode instead)
