Can't get LB to connect to Enjoywood E20 in Linux Mint 22
I have googled this issue and found many topics regarding this but none have helped me fix the issue. LB installed and works fine. It just (most of the time) won’t connect to the laser. I have confirmed I have permission. I have toggled DTR mode. I have logged out and back in. I have rebooted, and it will not connect. It worked yesterday but I have not been able to get it to connect since. The device is set to ttyUSB0, GRBL If I use my Windows laptop, it works fine. Help Please. Thank you
You can migrate your settings from the working one into the non working.
