Cant get lightburn too connect too my laser
i get no connection between Lightburn and laser but i do on older laptop Aswell home origin is placed way off on the other computer I’ve watched YouTube videos and everything still can’t figure it out
Go through all the steps to transfer the old config to the new PC:
As a newbie to lasers I hesitate to give advice but having had a similar problem I found that when I made sure that I was connected to the correct port it sorted the problem. If you go to the laser window you will see a box at the bottom left from which you choose your device and immediately to the right of that box is another in which you choose the port you want to connect through. Assuming that there is more than one port listed try choosing the different options to see if that corrects the problem
I’ve tried all ports and got no connection the video I’ve watched said comos 6 should be the one im looking for but it doesn’t show up aswell ive taken auto home off and ive tried setup my laser manually and still no connection ive followed every video too the t and got no were but itll connect on my old computer comos 3 if i used that same comos on the new Compter it wont connect
when on the old computer it conects but home is is way off it wont goo up down, left or right it like the only command that works is home but itll goo too the top left trying too goo off track
