Can't get material library to pop up anywhere after update
Hello, I use my material library a lot, but im not positive if its from the newer update or not but when i click on material library it wont pop up anywhere on my screen anymore. It even shows a check mark next to it under window, but its nowhere on my screen. Ive closed lightburn and opened. Still cant get it up. Any help would be greatly appreciated. Thank you!
You are using version 1.7.08 correct? Does the material library appear if you go to View>Reset to Default Layout?
im not sure if the reset did it or i went and closed out every window just incase it was hiding behind one without showing the tab but it ended up being there. Thank you so much! Now the fun part and try to remember what i need to go back and add! lol
If you use the option @JessN suggests, you will at least get back to the layout you first saw using LightBurn. :slight_smile:
