Can't Jog Xtool D1
Just got my Xtool D1 and everything works with Lightburn except jogging. Can’t jog with keyboard or
mouse. Tried all places I could find in settings to no avail . Any thoughts would be greatly appreciated.
I should have stated I have the latest Xtool firmware and latest Lightburn software.
Is the Xtool D1 a new device?
Xtool requires the use of their own device profile. I feel that you’ve imported xTool_D1.lbdev by this point ans selected it in the Laser window in LightBurn.
In the Move window, there is a Distance box that should have a number in it. If that number is zero the laser won’t jog.
I don’t have an Xtool D1.
In the Move window if I set the Distance to Zero, and try to click one of the jog buttons on the left side of the Move window I get an error message pop-up box telling me that the Distance is set to Zero with GRBL set as the controller in LightBurn’s Laser window.
If I select the xTool D1 in LightBurn’s Laser window and try the same Zero distance jog I get no error message - but again, I do not have the same engraver.
A screen capture of the Laser window and Move window might help us see where you’re at. A capture of the Console window in LightBurn is also informative and will allow us to confirm that you’re connected and that it’s not a communication problem.
There is an entry in the distance box. I can also select continuous jog which greys out the incremental jogs. I have configured Lightburn for the Xtool D1 and am able to create and burn projects. I just can’t jog. There is also a $J toggle in the settings I have toggled many times to no avail. This was mentioned in other posts to make the jog work. I am not at my machine and can’t get you the screen shots until tomorrow. Thanks for your efforts John. The Xtool I have is new just purchased.
Here are some Screenshots.
LightBurn_aPyzJXt3pZ
In the Move window, with the distance box greyed out and and Continuous Jog enabled… Does holding the jog button jog continuously in the direction you’d like to go.
I am in unfamiliar territory on this one.
I unchecked most of any settings. Homed the laser. The D1 doesn’t have limits but still homes. Lo and behold i can jog incremental but not continuous. I haven’t given up and will hopefully be victorious in the end. perseverance does pay off in my experience.
