Can't round corners on a SVG created in Silhouette
I’m trying to round corners on an SVG I created in Silhouette. Converting to a path isn’t a given option for the file (I saw this as a possible solution in another post). I click on the image, it turns into moving lines, but placing the mouse over it doesn’t give me any type of crosshair or way to do anything to it. I did a test square in LB and had no issues rounding the corners. Is it my file type? Should I be importing instead of opening a file? Thanks!
Try ungrouping
Lightburn only creates round corners between 2 straight lines. It doesn’t blend a radius between a straight line and a arc, or between 2 arcs.
Thanks, it’s a one piece file that was welded together. Maybe, that’s the issue.
This is totally straight lined…but, it is a welded piece, so wondering if that was the issue.
Is it a file you can share?
If so, others can look at it and see if the issue can be replicated.
Or possibly help with a solution.
