Occasionally I am unable to use the option Save RD File. I select what I want to save, click Save RD File, Enter the filename, Click Save. No error is given but the file is not created either. Same thing happens if I just hit enter instead of clicking the save button. If I then close LB and reopen the file and and do the same process if that works. Sometimes if I try Save RD File a few times without closing LB it will then work. I have this same issue on two different computers one running Windows 10 and the other running Windows 11. I am running LB version 1.0.06
Anyone else run into this? The big problem is that I can’t reliably recreate this issue but I would say it happens about 25% of the time when using this process.
