Can't see bottom of main screen
Hi There
Not sure if you can help me, since the latest Lightburn update the bottom of the main screen disappears off the bottom of my desktop, this is the same in either fullscreen or windowed mode. In windowed also you can only drag the main window sideways and not diagonally to retrieve the bottom on the window.
I am using a MacBook Air 2022 M2.
Many thanks
Chris Chastney
When in windowed mode, try double clicking in the top bar, near where it says ‘LightBurn 1.4.00’ - that should resize the window the match your screen size. If that doesn’t help, try first going to ‘Window’ > ‘Reset to Default Layout’, and then double clicking in the top bar.
If neither helps, please share a screenshot of what you’re seeing both in windowed mode and in fullscreen mode.
