Hi! Suddenly I can’t save my layer settings (I’ve tried “make default for all”, and i have a lot of settings saved, always like that, but now it doesn’t work).
After the “make default for all”, the name and setting of that color change, but once i open a new file, it goes back to the original settings.
What can I do to save my settings?
Thank you!
Do you mean you open a file that you had saved before? Because the layer settings are saved with every file, so if you open a file, it brings in the settings saved in that file.
If you mean you clicked File > New, then the settings you set as your defaults should stick.
In Edit > Settings, check to make sure you have this switch enabled:
