Can't use control E for eclipse tool using Acer laptop
Can’t use control E for eclipse tool using Acer laptop
What happens when you attempt to do this?
If you do this with an on-screen keyboard does it work?
I had to go to tools and clip on eclipse and now it seems to work.
What is an on screen keyboard?
The ellipse tool can also be accessed from the main toolbar. However, the CTRL+E shortcut should work to activate the tool.
An on-screen keyboard is an app that would show you a keyboard on your screen that you can click. I wanted to separate out the possibility of a physical keyboard issue vs something else.
