Carriage slows down each time laser is turned on
When burning an image, I would expect the carriage to move back and forth always at the same speed and turn the laser on and off when needed. What is happening is that it is moving back and forth at a constant speed most of the time, but when turning the laser on it suddenly slows/stops and then returns to the same speed until it turns the laser off.
The result is that the edges of my images are more burnt than the interiors, giving a bit of an outline. Not a bad effect in some cases, but not what I would expect either.
Am I missing something really obvious?
Using a cheap 3w Chinese laser with GRBL flashed, GRBL-M3
$0=10
$1=25
$2=0
$3=0
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=0
$24=25.000
$25=500.000
$26=250
$27=1.000
$30=1000
$31=0
$32=0
$100=80.000
$101=80.000
$102=80.000
$110=5000.000
$111=5000.000
$112=5000.000
$120=2000.000
$121=2000.000
$122=200.000
$130=5000.000
$131=5000.000
$132=5000.000
Set $32=1 - that’s Laser Mode vs Spindle Mode. In Spindle mode, the machine pauses when the spindle rate is changed (IE, the RPM for the spindle, which is the same signal used to drive the laser power).
In Laser Mode, the controller knows that the laser responds to the power change instantly and does not pause.
Thank you, Oz! I can’t believe how much you help everyone!
Just for the record, that can be set under Edit -> Machine Settings. Don’t forget to click “Write”.
