Hi there,
In my other laser and different software I also have CARVING DEPTH option to set, apart from carving power.
Is there anyrhing like that in Lightburn?
Hi there,
Using a fill, you just need to experiment with speed/power to find the depth you need. Lightburn has a test function: “Laser Tools> Interval test” and “Laser Tools>Material test.” You cam run these to find what will give you the depth you want. I suggest you save the best results in the “Library”, with a name including the material and the lens used.
