Center finder not working properly
Atomstack S10 pro, windows, ver 1.7.08, when using center finder, the on-screen dot doesn’t move Searched, but couldn’t find an answer.
How do I fix this. Thanks
Start with a review of the following, then tell us the exact steps you have taken and where things are not working as you’d expect, and we can go from there.
The center finder worked fine e last week. Then suddenly it didn’t. I loaded my project, opened center finder, moved laser to 1st position, red dot didn’t follow. Bare with me, im81 and not a computer whiz
I just ran thru the process with my diode laser and did not see a “red dot”. Your bio is hidden, so tell us if you are talking about the pointer on a CO2 laser.
Running Atomstack S10 pro diode
There’s no dot to show me where I’m setting the 3 points when using center finder
I have no red dot on my diode laser either. In the Move window, set your Power to 0.25% and click on the Fire button. You will get a nice bright blue dot. That is exactly how I did it.
If yours has a red laser that points to where the laser will fire, and it is not working, then check the wiring and connectors for the laser pointer.
Thanks, I’ll try that, hadn’t thought doing it that way.
