What tool in LB can I use to center a circle at the end of a line.
Draw us a rough picture of what you want. Our crystal ball is broken. There are several different ways to interpret your question.
Align is likely the answer.
I might use the center of the selected circle as the drag handle, and with Snapping enabled, drag the circle to snap to the end of the line. If I have misunderstood your request, please do as @JimNM suggests, provide an illustration, and we can go from there.
How would you accomplish that if you want no line on the inside of circle? Node edit?
Your solution is the way I have been doing this. I was hoping for something that deals with alignments.
Illustration or example of what you are after would help with clarity.
One way, and without further design details.
But the circle is not centered with the line.
Being unable to make fancy screen movies:
- Drag center of circle to snap on end of line
Node Edit
the line- Cursor over line segment inside circle
T
to trim off that segment- Profit!
If that’s not the alignment you want, more info will help guide us.
