I have created a frame and then a text object on a different layer within that frame. I want to quickly center the text object within the frame. I watched a video that did that by selecting the object and then pressing the keyboard “C” key. This does not work for me. Neither does the “Align … hoizontally” button at the top. I’m stumped.
You need to select the text object, then with ‘shift’ pressed select the frame, then press the ‘target’ (align both horizontal and vertical centres) tool on the top tool bar.
There is probably a quicker way to do it though
But they don’t. If I do the following…
Create a new project
Create a frame
Create text within the frame
Select the text object
…then neither C nor E nor any of the toolbar alignment buttons do anything. It seems to me that one of the following must be true:
There is a setting that I have missed
I am doing something wrong
My copy of LB is defective
Whatever the problem, I need this fixed, as I spend most of my time manually centering things, and this is a total and unnecessary waste of time. I hope you can help. Thanks.
