When creating a Chamfer operation, there is no final depth option.
Thank you for bringing this up.
The Chamfer OP does not need a “Final Depth”, because the depth is being calulated from the bit angle and “Chamfer Width”.
I’m forwarding this to our devs, so that the warning won’t show.
Note, that a V-Bit must be used for the Chamfer Operation
In this case, the final depth is being calculated wrong, it seems.
That makes sense …
i did creat a ‘Chamfer Bit’ folder but did not give me the ‘Select’ option when
assigning to a project process..
will change chamfer bit to V bit when next out in workshop.
cheers
