Change frequency HZ
Hello
little you one with a ruida controller change the frequency HZ in command line and if so its used for what thank you
I am not following your questions here. Are you asking how to change the Frequency setting in your controller? What are you wanting to do? What have you tried and what results are you observing?
Hello
no I ask what is the point of changing the frequency HZ and if lightburn can change in short work
thank you
