Change layer colour from cuts/layer tab
When I purchase a file, the layer colours do not match the ones I have set up in Lightburn. For example, there could be a number of parts that are green, which I have set for engraving, where I need to to be black for cutting. Currently I have to ungroup and select each part and change the layer, which can be quite time consuming on complex designs. Is there a way of selecting the layer in the cuts/layers tab and changing the layer, so that all parts that are on one layer, change to another? Hope that makes sense.
Thanks
You can select all objects that are on one layer by holding down the ‘Shift’ button and left mouse click the ‘layer’ in cut/layer settings
You will then be able to change them to another layer colour
That’s great, thanks. I knew there must have been a way to do it. That will save me so much time.
