Change limit switch position
I have a Sculpfun S9 with S30 motherboard and working limit switches in the lower left position. Now I realized that it would be more appropriate for the home position to be on the top right. I wonder what I have to do to achieve this goal?
If the firmware from the S9 allows it, you should be able to move the endstops and your home position.
You could just try it and hit the emergency stop if it doesn’t work. After 10 minutes you are ready again with the original setting.
It’s explained step by step here:
Thank you !
Another question, if I leave the limit switches at left down position, can I use some command to set the home position to the upper right? So that after finishing the work, the laser moves to the upper right position.
You usually don’t do that with another home position, but in device settings you can set a “return to finish position” value, so you could send it anywhere after the job, e.g. 400,400.
This solution satisfies my wishes. Thank you!
