I have a 5W 12V AtomStack, I want to change the laser for a 20W 24V one. What should I implement to be able to adapt it to the new laser module?
You probably need to change your control board to one that outputs 24v.
Or add a 24v power supply and modify the wiring. If it is an Atomstack 20w module, they should be able to provide everything you need (cables and instructions) for making the upgrade.
Just change the power supply and the laser module. All mainboards I ever came across can be used with either 12V and 24V without any issue.
If you have an air assist that is connected to the mainboard directly, this needs to be changed as well, but I think Atomstack didn’t have this in the early models.
