I have a graphic (a grayscale JPEG) which is a rectangle.
The piece of wood I want to burn it into is not precisely a rectangle. the right side is about 5 mm shorter than the left side.
I want to grab the “node” of the upper right hand corner and drag it down 5 mm so that the picture is no longer a straight rectangle, but a kind of trapezoid… (It won’t warp the picture noticeably.)
Masks . . . in Lightburn? I didn’t know about those, but I understand the concept from Photoshop. I thought I could probably also “warp” the JPEG in Photoshop, too, but I just wondered if there was a similar feature in Lightburn.
I’m not as familiar with nodes as I should be, but I wondered if nodes even work with JPEGs besides Lightburn line segments. I think my question also has to do with what extent JPEGs can be transformed, warped, masked, and edited in Lightburn.
One is to cut the picture into shape. That way it is not distorted, you just lose a bit at the edge. For this LB has the feature to cut out (or away) any part of a picture. You create a shape and tell LB to cut the picture accordingly. (There’s a nice chapter on this in the documentation.)
The other on is to distort the image as you asked about. Sorry, no idea on this one.
