Is there a way after you start a burn to change the speed and or power? If not will this ever be added in future versions?
If you are using a Ruida DSP, you can override the speed and power settings at the machine using the control panel.
There isn’t at the moment. You can vote for it here by clicking the up arrow beside the number at the top: https://lightburn.fider.io/posts/546/spindle-speed-overrides
@Stroonzo no sir I’m not, but thanks!
