We have recently installed LB on a LAN, where each machine is running Windows 10. The software will run (despite about 6 error messages - that’s for another post) and we could configure it to pick up the laser cutter on the network. The laser cutter is a Chinese manufactured machine, which originally had a Leetro 6515 and which we have just replaced with a Ruida 6442S controller so that we could use LB instead of LaserCut. The problem we have is when a new student logs into a machine that has LB installed, it has to be set up to pick up the laser cutter. Then if another student uses the same machine, logging in with their own account, LB has to be set up again.
The question I have is: can you get LB to point to a shared folder (e.g. on the C: drive) that contains a prefs file that can be used for all students? I cannot find anything as such, but perhaps it is something hidden away.
