Hi there, I am working with a paid version of lightburn 1.4.03. The thing that i want to do is to change the path of my laser towards every laserpiece. This because the pieces i need to laser are higher then the laserhead. This means if the laser does it’s own thing it will crash into the higher pieces of the work. So i want to manually set the route that the laserhead should go to laser all the pieces. I need to laser 5000 units, so i cannot do this by hand…i need to set this up for 1 sheet and then it can replicate.
Hope someone can help me…i even asked chatgpt and he/she sais it can be done but i cannot find the given solution in my version of lightburn.
Can you elaborate on how this works? Are you expecting to dynamically change the focus height?
How much precision in the path do you need? You won’t be able to directly control traversal moves. The best case is you should be able to control shape by shape order.
How will this work? You adjust the laser head such that it sits correctly in relation to the work pieces. Not to the bed. So you should not need to change the head’s height at any time. Except each piece has a different height…
No the laserhead wil always stay at the same hight, but my work is like a small tower…but at the foot of the tower there is a small round plat where I need a hole in. I need to do do 15pcs per run.
I guess the easiest would be to use the options PY described. But if you have so many objects, is it reasonable to change the optics to have a much longer focal distance? I don’t have any experience with CO2, but I noticed that you can exchange lenses to get different focal distances and lengths. So that might be even easier.
I would also suggest looking at this option. Would potentially eliminate having to do all the elaborate setup if you could just clear the height of the pieces.
