Change to button layout
Hi, I hope I’m putting this in the right place if not do excuse me. I’d like to request a change to the buttons on the laser control panel in Lightburn it would be really nice if the enable Rotary button was moved away from the home button and the home button made a lot larger ideally the same size as the frame button to make the programme easier to use with a touch screen. The problem I’ve had is that when tapping the home button I’ve accidentally engaged the enable Rotary which stopped the laser from moving across the wood causing a small fire. I hope you find this helpful. Love lightburn.
