Changed $3 settings as advised but now machine not going to certain directions
i had changed it back to default now when i try and send the laser some were it frames about 10 mm away from starting position although burn is about 200mm away
this are my settings
$0=10
$1=25
$2=2
$3=2
$4=0
$5=0
$6=0
$10=3
$11=0.010
$12=0.002
$13=0
$20=0
$21=1
$22=1
$23=3
$24=25.000
$25=500.000
$26=250
$27=1.000
$30=255
$31=0
$32=1
$100=800.000
$101=800.000
$102=800.000
$110=2000.000
$111=2000.000
$112=600.000
$120=50.000
$121=10.000
$122=10.000
$130=500.000
$131=400.000
$132=100.000
Lightburn is a wonderful program and you don’t have to mess around with the $value variables that mean nothing to humans.
Use the ‘Edit → Machine Settings’ to read, save, load and write them via Lighburn.
Since the issue was it’s location being off, you should not by toying with the directional controls of the axes…
Make sure you save the ‘factory fresh’ setting, so when you lose a controller or break it, you can restore them.
Take care…
how do i do this buddy how do i reset it ?
i have changed it back these are my settings is this right?
$0=10
$1=25
$2=0
$3=0
$4=0
$5=0
$6=0
$10=3
$11=0.010
$12=0.002
$13=0
$20=0
$21=1
$22=1
$23=3
$24=25.000
$25=500.000
$26=250
$27=1.000
$30=255
$31=0
$32=1
$100=800.000
$101=800.000
$102=800.000
$110=2000.000
$111=2000.000
$112=600.000
$120=50.000
$121=10.000
$122=10.000
$130=500.000
$131=400.000
$132=100.000
ok
That’s why I use the Machine settings, I don’t know these numbers.
The $30 value needs to be equal to the ‘S-value max’. Mine is set for Lightburn default of 1000
That is in the Common Grbl Setup from Lightburn.
But I don’t know without more information…
Good luck
