I changed a setting in the machine tab. Tryting to get my machine to go home Via the Lightburn software. I’m working with a Longer Ray5 5w laser cutter. I can’t remember the exact setting I changed, but it was some home setting that was set to false that I switched to true. Now when I power on my laser. It just starts to travel up until it hits the top and keeps on trying to go up. When I go back into the machine settings while it’s on, I get the controlled failed to connect and I can’t change any values. Added pictures below.
fixed it! Removed my laser and found it again. Turned off auto send to home and it let me back into the settings.
Take a few go to Edit → Machine settings and save the file. Next time you break it, you can just reload the configuration from this file.
Always make a backup before changing anything
