It appears that if I make a change to a lightburn setting it does not become active until I switch off and then back on again, the new setting is then active, seems a very slow method of changing, an “ENTER” is usually sufficient!
I responded when you previously posted this.
Can you provide a specific example and steps to reproduce this? I’ll try to see if I can get the same results but I’ve not see anything like what you’re describing.
There is a youtube video, not sure of the guy’s name, showing the same problem with the change slot function
Yes. That’s a known scenario and has been acknowledged. Note that the issue can be worked around by tabbing out of the field before pushing OK.
More information here:
Are you seeing this elsewhere?
