How to change jog distance in lightburn…I tried changing that in the “move tab”…but it wouldn’t change
What are you trying to accomplish?
If you want quicker jogging movement it might be easier to use “Continuous Jog” in the Move window.
Otherwise I believe the actual jogging distance is a setting within your controller.
I need a lower jogging distance in order to use the print and cut option
Thank u …I figured it out with your help
