I have a simple request for the next update to LB (on Windows). I would like the Line Interval changes (up/down arrows) on the Cuts / Layers window to change by 0.01mm (not 0.10mm) with each arrow press with the mouse so it matches the same 0.01mm change when you open up the Cut Settings Editor. Changes by 0.10 are typically way too large an adjustment anyways.
