Changing operational setting while engraving/cutting
Can one change the setting on a running job using shape properties. If you can, please explain, if not it’s not the end of the world. I"ve tried and didn’t seem to get anywhere :>)
This is by design. When you run a job on the laser, LightBurn builds a file internally that contains the whole thing and begins streaming it. You are free to load a completely different file and work on it at that point, without risk to the running job - none of the edits you make will affect a job after it has begun sending.
Thank you for the answer, so essentially your locking in the parameters for the program even if you attempt to change the values while running at the shape properties box.
