I am unable to change the scan angle when I am engraving 2 layers. The primary layer is set to 45 degrees but the second layer will not exhibit the scan angle window when opening the cuts widow. Beginner mode is turned off for both layers. Any suggestions???
Show us what you are observing, please. ![]()
i have gone back and verified that beginner mode was turned off when editing both cut layer settings. thanks for your help.
I thought I had looked at this screen a hundred times and could not find the setting. Don’t know what I was thinking at the moment. I apologize for taking up your time. Thank you once more.
No worries. All good, glad this is sorted. ![]()
