Is there a way to make the arrow keys move an object in different
increments? Default appears to be 5mm.
Edit → Settings → Display & Units → Shape Move Increments
And you’re done!
Thank you Sir!
I found the setting. Why is it set for 1.0008mm?
To use the modified setting I need to use the “command” key in conjunction with arrow keys
This could be an approximation from an inches conversion.
There are 3 separate settings that define the behavior with just arrow, shift+arrow, and command or ctrl+arrow.
Make sure you’re changing the appropriate field that you want to change.
