Is there a way of easily changing spacing between words rather than letters in lightburn? I know I can convert text to path and move the individual pieces but I wondered if there was a simplier way that was consistent.
Iâm not sure if this will help or not.
Once they are objects you can select them all and use the âalignment toolsâ
I was surprised how easily they worked. If you have letters such as
You will have to group them, if you want to center circle, as they are separate pathsâŚ
Donât need any kind of âboxâ around them, just selecting them should make the tools available.
Good luck
Not really simply. One workaround.
- write each word as a separate object
- Put the two outer words at the 2 far ends of where you want them placed
- Select all words
- Use Arrange->Distribute->Distribute H-spaced
This will spread all the words evenly.
Iâm not sure what youâre referring to here. Are you talking about doing this in another application?
Itâs a necro-post from a spammer trying to establish linkbacks to a site that âspinsâ original source texts to generate âcontentâ for someone trying to populate a site with statistically correct but meaningless English gibberish.
Iâve flagged it for proper disposal âŚ
I considered this as well. The user profile is interesting because the details are relevant. So either a hacked account or clever account creation.
