Hi all, I am new to lightburn and am designing a laser test board for materials, my problem is when I run the preview it engraves the labels first, which is ok, but then it wants to cut the part out of the material before cutting the test swatches out, I know it is probably in here some where but not sure what to look for but do you guys know how to change the order of what the laser will cut since obviously if it cuts the part out first before the swatches then the part won’t be held in for the rest of the cuts? thank you.
