I am aware here on the forum that this problem exists and has not been solved, so I bring it up again to find a solution.
Grateful for the attention.
System: BigLinux (Manjaro)
Lightburn 1.3.01
Lightburn 1.3.01
This is because the update requires an older version of libSSL.
If you install libssl1.0-dev that will work. In most newer distributions that package is deprecated or no longer supported.
Thanks for the clarification. Although this library is not used by Manjaro, I will look for an alternative.
Ah. Sorry. I misread your distro. I thought you were using Mint.
Might be available in openssl-1.0
package but not certain.
