Hello, I have a Just purchased a 100 watt omtech, I was wanting to know how long should I run the chiller after shutting down the laser?
I’ve put my CW5000 to 20 degree Celsius when I’m done with my tasks or I have a longer break in the work process, I turn off the extraction and the cooler.
If you consider that the laser is off, not generating any heat, and the thermostatic controls on the chiller keeps the temperature within a safe range when it is working properly, there really isn’t a need for a cool-down period.
I agree here - once the laser tube is off, no more heat is being produced. The volume of water that’s in the tube is likely more than sufficient to keep the temp from spiking even if water flow stopped immediately after the laser stopped working.
