Originally did this on my CNC machine then decided to redo into Lightburn as a door hanging. Run the file as is to make guide lines and cut out project. Then turn off red layer and change power and speed to cut out parts on black layer
Three Balls.lbrn2 (311.0 KB)
Do you spray paint the parts before or after you cut them? Or are they cut some some other material?
I spray paint the parts after i cut them. They are Baltic Birch Plywood. 1/4 for the base and 1/8 for the cut parts
