So when i set up my chuck rotary two days ago it worked fine. Today i set it up and tested the steps per rotation. It spun for 5 minutes then spun the other direction for 3. Does not matter if its set to 1 or 20k steps per rotatio
What are you doing exactly to test this?
Sounds like it’s attempting to home… how do you switch to the rotary?
Did you enable the rotary?
