Circle center finder. Wrong result
Bonjour à tous
In the XTOOL S1 laser, when I use the circle center finder, the result is wrong. The calculated center position corresponds il to the top of the circle…
I am using the last version of light burn.
In advance thank you for your help
Finally, after doing some research with our favourite LLMs, I found the solution:
Before launching centre finder, you must disable the option to enable pointer offset (device settings / Dimensions).
Once the centre has been calculated, simply re-enable this option.
