Circles not round
Hello,
I‘m working with a atomstack x20 and do have some serious issues with lasering circles.
But I already did notice the fact, that if I laser a „large“ circle, lets say 200 mm in diameter, I barely see signs of a not round circle.
If I start the job with a „small“ circle, lets say 10-20 mm in diameter it will end up with a unround circle.
Please see the picture in the appendix.
Also I tried my best by calibrating the x + y axis but unfortunately I think I messed up this process by simple trying to calibrate those axis over and over again.
Is there a chance to factory reset the atomstack x20 + lightburn Software?
Thank you very much!
Best regards fabian
Edit:
I also did check the tension of the belts and configurated them as they should be.
Thanks!
It is most likely a loose setscrew holding one of the pulleys to the motor shaft or a loose screw holding the gantry together.
Working through all the mechanical issues in this description will help you find the culprit:
https://diode-laser-wiki.com/documentation/guide-to-mechanical-adjustments/
That’s for a Sculpfun laser, but the mechanical components are pretty much the same for all desktop diode lasers. Pay particular attention to all the places where mechanical backlash can creep in.
