Hi Guys, I am using the Atezr P20 laser. Lightburn v1.3 The fire button is enabled. When I do a square FRAME the laser fires to show location on the board. When I do a Circular FRAME the laser does not fire. I tried to fire the laser first and then hit Circular Frame but it turned the laser off.
Is this something within Lightburn or is this something within the hardware? I would like to see the laser fire during a Circular Frame if possible
I had the same issue with the p20 plus. The only way i can fixed it was when i turn the fire power to 5%. but for the square frame it is way to much power. 0,5% is perfekt…
My other laser Ortur LM2 had no problems and makes perfekt frames with 0,5% power on square and circle frame. Maybe there is a better solution but this works for now
So I believe what you are saying is: Just before I do a Circular Frame set the power to 5% then back to .5% for square frame? Do I understand correctly?
well I had to do a recent firmware update last night on the laser for another issue and NOW it appears that the laser does fire at .5% in both Square and Circular mode.
Thank You for responding so quickly - your assistance and ideas are most appreciated.
