Clarity of lines being engraved after AI image
I am attempting to engrave a cross that i generate from CHATGPT and i put it into the LightBurn software but it still isn’t a clear cut design on the insides i generated a svg and dxf file and still the clarity is limited on the output it seems there is small little defections in the generated image. Any solution to this ? i tried the edit to optimize it but still lacks the clarity i desire. Thank you for the help !
You provide nothing to test or examine. With no image, we cannot see your issue.
Upload your SVG file and your .lbrn2 file so we can investigate.
The Import doc has a caveat:
Use caution with AI-generated files
If you use AI/LLM tools to generate files, please be aware that the files generated may not conform to standards for the file type you’re importing and you may experience failed imports or unexpected results.
In other words: garbage in, garbage out.
Thank you for the help! Do you have any recommended way to be able to do it then besides drawing all the designs myself ?
For folks like me who cannot draw a straight line without getting my thumb in the picture, a not-awful way is to combine elements found out there on the Interwebs.
For example, a casual search for “crosses svg” brings up a zillion hits, among which:
The fact that they’re (apparently) intended for Cricut machines is irrelevant; an SVG image is what you’re looking for. Nowadays, however, you will find AI-generated garbage, so don’t expect every image to be perfect, particularly very complex images.
The same site has frames:
Download a cross and a frame to get two SVG files, import into LightBurn, put them on a Fill layer, arrange & resize as needed, set the speed & power, then Fire The Laser:
Stipulated: not the most appealing design. :grin:
There are licensing issues (“not for commercial use”), the question of “free” vs. “stolen” designs, copyright questions, and so forth and so on, all of which you’re free to resolve as appropriate.
Thank you so much for the help again it also seems like even the straight lines my machine is not cutting correctly. i have a 300 watt commercial machine so i think it might be a little different from the other ones if you want to send me a private message if thats a thing on this forum so i can contact you for more help or whatever is best for you to share your experience with me
We try our best to help folks right here in the open so everyone can benefit. If you’d like to share your design so we can see where the issues are and recommend a good solution, we’re all ears. You can also email us directly at Support@lightburnsoftware.com if you don’t want to discuss publicly.
