I’m just learning and I’m trying to cleanup an image so I can cut it. The image has gaps and I’d like to be able to go and fill them in. I can’t find a tool to do that and I’ve checked the documentation
You can usually do it manually, but in your example it is too much work. It looks like you’ve traced your items, can this be done a little more accurately? Try uploading your starting image here and we’ll look into it.
I tried to trace your image and clean the result afterwards, but it was not good enough to be put together, which is the point.
So it was better and faster to make a new one. I hope you can see my steps in the file, otherwise feel free to come back. Påskeæg.lbrn2 (214.1 KB)
